longfields don't fit
tunica, ms
tried to put my longfields in lastnight and they're too big. i thought they were supposed to fit right in there. am i supposed to grind the housing? are there some housings that are smaller than others? this was a soa rig when i bought it, so i have no idea if the po put a different housing under it.
what year housing?
take some measurements of the birfs you removed versus the Longs...if the length of the shaft itself is about 3/8" longer on your old ones, then you have the oddball 76-78 birfs...and they are slightly smaller than the 79+ and Longfield product.
You'll need a 4-1/2" angle grinder to "open" the fish-mouth area of the axle housing...about 1/8" or less, top and bottom....basically, the distance across the flats of the birf is a hair wider with the Longs.
If they measure the same, try loosening the top steering arm...don't even remove, just loosen. My drivers side requires that for installation....
you can leave the knuckles on....just stuff rags around to keep the shavings from contaimnating the grease/bearing areas....
that WEK outta fetch ya something....people break them enuf, a partial kit is good for spares ;)
you are only clearancing the end area...outside where the steering arms are...part of the housing itself, not the knuckle...the red circle area, top and bottom....and not much material either...
it IS easier with the knuckle off tho, just takes more time....
I used a dremel with a carbide burr to open up one side of my 75. Just make sure you wear leather gloves and heavy long sleeves. It takes forever to get all of the slivers out!!
Tony
woody said:
Finally, a great pic of the specific part that needs to be ground down. That'll help a lot of folks Woody!
I don't know about Longs specifically, but every disc swap I've done has only required grinding on the top lip OR the bottom lip, but I guess half as much grinding on 2 surfaces is a better way to do it...
2 surfaces is slightly better....mostly cause if you need to offset the birf/inner too much during installation, you risk damage to the inner seal...while I carry a half dozen at all times :rolleyes: most folks dont....lol
I did this to my 76 SUA housing to fit mini birfs and just did it again this past weekend to my new SOA housing to fit the Longs - kinda confused as I remember taking a ton of material off the 76 housing - but the new housing I got only needed a little under 1/16" top and bottom - mostly on the bottom. The opening is a nice clean fit - but boy it's tight in there.
One bit of advice - be sure to have the diff in the axle housing - and test fit with an inner fitted into the diff. It's easy to just get the bell to fit - getting it to fit and line up when installing into the diff takes a little more test fitting/grinding.
Grinder is easiest and cleanest method - nice and easy to clean up metal dust.
Why would you work through the knuck instead of removing it? I take the dial off my hub, pull the snap ring, reinstall the dial, remove the wiper from the in board side, then pull my steering arm and the lower cap and pull the whole knuckle, rotor, spindle ect. off at once, then hang it with a rachet strap so the brake line isn't stretched. I'd hate to have to completely disassemble the whole knuckle to get in there. IMO, this is the easiest way to undress this axle to get at the birfs.
i waz replacing the hubs and spindles anyway.
another interesting thing i figured out is when you torque the steering arm bolts down it closes the fishmouth slightly. this is why i had to pull my knuckles again. i didn't think i had grinded enough, when i had plenty of room to put the longfields in without the knuckle on.
it wouldn't fit, so i loosened the bolts and it slid right in.
