Longfields and CM inners are installed!!!
CreeperSleeper
Cascade Cruisers
Canby, OR
I'm so happy to tell you, my Longfields and CM inners got installed last night! :bounce::bounce2::bounce:
This should effectlive end my broken birfs... Just for tech point of veiw, I swapped them the quick way (left the knuckle on the housing) mainly because I didn't have all of the parts to rebuild everything. However, it does have new inner and outer oil seals (buy OEM, so worth it compared to the aftermarket crap and it's about the same price) and I repacked the bearings. I will be making an order with CDan for the rebuild kit and new wheel bearings when I do my 5.29s. Also, I would recommend buying a good set of snapring pliers before you start. I stabbed myself with a screwdriver pretty well. :doh:
Anyway, the only snag that I ran into was the last time my birf broke, it took a few teeth out of my ABS ring. I looked at it and thought, "Hmmm, might still be good" and thru it in. I have badly pulsing brakes until the computer realizes that something is not right and shuts the ABS off. I suppose I will just pull the fuse and panic brake old skool styles. (aka, pump faster!)
All in all, I was amazed with the speed and service that Bobby & Tina Long offered. Their products are top notch and I couldn't be happier.:cheers:
not trying to hijack your thread....
but talking about inner oil seals and aftermarket crap.....doesn't marlin make a heavy duty inner oil seal for the 40 series? Wonder if he is planning on making anything for the 80? Are his heavy duty seals crap?
NO! Marlin's Heavy Duty seals are AMAZING! They just don't work in an 80. :crybaby: I'm saying that if you go and buy one from Napa and an OEM one and compare it, you can see why the Napa ones fail so quickly!
Sorry for not making myself clear, I left out MC seals because they are not currently for the 80. :cheers:
Also got my new anti-Jeep sticker and plates on... Maybe a pic will get more responses! :flipoff2:
I must have gotten that same Jeep thing. But I got it from Denver nuggets cheerleader.....:frown:
