Longer Shocks
Kingsport, TN
Website
tired-iron.mounet.com
I ramped my Cruiser with the rear shocks disconnected and it appears I need a set of shocks that are 30" from the bottom of the threaded stud to the eye when fully extended and 20" from the bottom of the threaded stud to the eye when fully compressed.
I have a set of OME shocks that are for the "J" springs and they are 3" too short.
Any of you "Parts-Jockeys" know what I need?
From your measurements you need 10" travel shocks, the L shocks are 11.5". Just space the top shock mount down ~3" and you should be good to go?
I am with "tools" here. My shocks didn't reach down enough, but had 3" extra travel when compressed. I cut 4 3" lengths of 1 1/4" x .120 wall tube and tack welded them onto the top of the upper mount. I bought longer bolts and put the shocks back in. I left the springs out and compressed the suspension. The mod not only uses all of the shock travel, it angles the shock inward at the top, improving the geometry. It works well.
Are you using all of the up travel on the Ls? If not use your mad skills and fab an upper shock mount that is ~3" lower. I'm sure you've got metal laying around your place to fix just such a problem.
Let's not forget you're the first guy to comment on the one off stuff here to the effect of how awesome it feels to create something from scratch. Show something new oh wise and innovative one. :cheers:
I like my 14" travel Rancho 9000 XL's myself. Big body, big shaft, lots of oil, specifically made for big heavy trucks like yours...
