Long side inner axle help
Carolina, RI
Website
www.yankeetoys.org
The patient, 1997 Lexus lx450. I'm wondering if there is supposed to be a c clip on the inner axle so that the axle doesn't slide too far into the birfield like on a mini truck?
If your referring to the inner birf mating to the outer birf than Yes, if your referring to the outer birf through the spindle than Yes. Just did it today. If you put a screw in the outer's hole after putting the spindle on you can grab it with pliers and give a gentle tug. It should give you the access to the c clip grove.
Your photo shows a c-clip attached still, at least it seems so. I'm doing the same job so I'm just making sure I'm not missing anything. I'm not going to separate the birf this time and see how it goes.
