Long distance hikers
Nashvegas
Those of you who have gone out out for a week+ hike, what gear did you take with you? I am still planning on thru hiking the A.T. this year. I am going to pick up a MSR whisperlite international and Katadyn hiker pro filter. I pretty much have everything else.
Marmot Eiger 65 pack
10 degree sleeping bag
Goretex pants and coat
Mountain Hardware light weight fleece
REI Clipper tent. ( I have looked at hammocks. I don't sleep well in them)
trekking poles
Sorel Timberwolf boots. ( I like the ankle support of a heavier hiking boot)
Wigwam socks ( I am thinking 3 pair)
Wicking shirt to hike in
Thinking about a kilt to hike in
That's about it for the big stuff. Any ideas on food would be great too. Any recommendations onany other gear would be great. I have done some test hiking with my pack and gear and I am on the heavy side at 45 lbs. I haven't had any problems with the weight. Hopefully next week I will get to go on a multiday with all of my gear and see how it goes.
I would pick a lighter stove, unless yah planning on doing some winter camping...later down the road...
I dont know how the mosquitoes are on the AT but if they are anything like in the sierras bring a head net and a hat with a round brim. A hiking umbrella.
I can eat pretty much about anything so I usually bring Dehydrated food.. but among others things I have had peanut butter with flour tortillas and although I dont eat Mac and Cheese I love it when I go camping..
Good luck !!
Looks like you are going to have tons of fun..!!
hiking
mole skin (or band -aids) for blisters; water filter or tablets, water proof matches; powder gatorade and like manuchao says dehydrated food or MRE'S from your local army supply store. nylon string to hang up wet clothes or just in case emergency repairs. hope this helps, good luck and be safe.
Lighter than the whisperlite?
I did two weeks on the Florida Trail in 2006. Some things I learned/found helpful were:
If you will be in an area where you might encounter mosquito's, ticks, biting flies etc. bring plenty of bug spray. They can make you absolutely miserable.
Bring some kind of pillow. I didn't, figuring I would use my pack or extra clothes, but wished I had. A good sleeping pad is also a must.
Pack a small, thin towel. You don't need a full size one, and thin will dry faster.
Invest in several pairs of good synthetic or wool socks.
Cotton clothes suck. They absorb moisture and take forever to dry.
You will eat less than you think, but pack plenty. Good staples are ramen noodles, quick cooking oatmeal, and trail mix. I would cook oatmeal and mix in some trail mix to add some flavor, and snack on the trail mix throughout the day. I also like to stuff my cheek with sunflower seeds and eat them while I hike, gives you something to do and the salt tastes great.
Wet wipes!
Gold bond powder, for your feet, crotch, armpits, everywhere.
Water proof you tent thoroughly before hand, also practice setting it up.
Bring some "100 mph tape". It is an extra strong military version of duct tape. You can use this for just about anything, patching holes in your tent, repairing tent poles, fixing shoes. While you are at the surplus store pick up some parachute cord as well, light and strong, you can also take it apart and use the small inner cords for fishing line or sewing thread.
Learn a few good knots.
Avoid packing things in rigid containers as much as possible, using sturdy flexible bags saves space and allows more flexibility in packing.
Make a good walking stick.
Bring a multitool and a larger fixed blade knife for things like chopping and digging. Don't forget a small sharpener of some kind.
Bring a bic lighter as well as waterproof matches or a fire starter.
A good hat and sunglasses are essential, as well as good boots. Break the boots in and water proof them before you go.
Underwear is unnecessary.
Strong black garbage bags have many uses, as a poncho, tarp, to keep wet things separate in your pack.
Get a good map of the area you will be hiking study it and commit to memory as much as possible.
Even if you have a gps, bring a good compass, and know how to use it with a map.
A led headlamp and small bright led flashlight. Don't forget extra batteries.
I don't know if you smoke, at the time I did, nothing like a little bit of high test after a long day on the trail to relax.
Brush up on first aid. It's a good idea to pack a sheet with first aid instructions in your first aid kit. Military surplus has nice compact kits, the wound dressings that form clots to stop heavy bleeding are good to have. Pack benadryl in your first aid kit, if someone has a bad allergic reaction it could save your life. If you have a known allergy to insect stings you should bring an epi-pen.
Make sure you are staying hydrated even if you are not thirsty.
Get used to walking before you go, take day hikes with an increasingly heavy pack leading up to your long distance hike.
Get a full body massage when you get back from your hike. My shoulder muscles were so used to having a pack on they thightened up on me when I got home. That massage was the best feeling I have ever had in my life, better than getting a blow job while hitting a hole in one with a winning lottery ticket in my pocket, seriously.
The first week is the hardest, after your body gets used to the routine you will become a machine.
Yah.. snowpeak gigapower and MSR pocket rocket.. are about 11 oz with a canister good for a few days for one person..
The Whisperlite is about a pound and that does not include the white gas and container.. so that would put yah at around 2.5 to 3 pounds already....
Whisperlite stove is great for winter and high altitude areas, not the case on the AT trail...
just my .02 cents...
I am going with the whisperlite int. because acquiring fuel for the canister style stove isn't always easy. I will suffer with the weight of the stove.
jts- Good info. I think we are on the same page as far as gear. Some high test after a long day on the trail sounds excellent. :smokin:
This guy has all the right ideas and lists:
Andrew Skurka: Home
Wow, great link.
jts has some great tips. the tape can be wrapped around your hiking pole. get a packtowel from REI or where-ever. If you buy a large you can cut it up and have 2. A lightweight drybag can be used as a pillow.
My 2c: Bandanas are super-useful and dry socks before bed are da shiz...
Billy goat would be a very interesting person to meet.
Good to know, thank you! I usually pack in with my ALICE ruck and quite a bit of Military gear, Gore Tec and Bivy sack. Although I have upgraded my sleeping bag to a Marmot and use a good sleeping pad now.
Oh for gear and clothing and such Definately bring a sewing kit then you don't need as many changes of anything but socks, and the sewing kit will come in handy for many other things as well. Also I always carry a Sewing Awle. (I don't think I'm spelling it write since I can't find one on google) but they are great for heavy gear repairs ie boots or pack. Also you'd be surprised what you can make with one...
Oh and a military style two quart canteen about half full of water with the air pushed out of it makes a money pillow!!! Unless it gets really cold. I usually leave it out of my bag and under my head.
WhiteBlaze
Similar to mud for AT hiking. Forum members can be a bit sensitive tho. I got bounced for having a mild disagreement. Lots of good info.
I have the whisperlite and have used it for many years on and off the AT and never had a problem finding white-gas. Alcohol stoves, new or DIY, would be the lightest and easiest to refuel. Decide how you want to sleep. Shelters...Tent...hammock....tarp? Personally, I avoid shelters at all costs and stealth camp only with either a tent or tarp.
I love my bivy sack, but in truly foul weather it can be wearing for the long term. It's nice to have a place to truly be able to get in out of the weather and get dry without fouling up your sleeping gear...
Wow, great link.
See the guy's stove choice: DYI alcohol stove...
I have backpacked most of my life. One of the lessons I learned long ago is you'll need less gear than you think. My last trip was 14 days, no resupply, in the Absoroka Beartooths. My pack, with food minus water, weighed in at 42lbs. I never went without anything I needed. However, I am not a true lightweight guru but consider myself a mid weight backpacker.
Buckru, I would love to know what your pack consisted of.
Here ya go,
Clothing
2 pair socks and 2 pair liner socks (wearing one pair of each)
1 Expedition weight socks
1 pair convertible pants (wearing as shorts or pants to start)
1 Mid weight poly pro thermal pants
1 Set Rain Pants
2 pair wicking underwear (wearing 1 pair)
2 wicking short sleeve shirts (wearing one)
1 Long sleeve light weight poly pro thermal top
1 Nuptse down jacket
1 Rain Coat
1 windblock hat
1 Pair gloves
1 Pair Tevas for camp shoes and river crossing
1 bandanna
Cooking
MSR Dragonfly and appropriate amount of fuel for trip
1 non stick skillet (size depends on group size)
1 Pot with lid (size depending on group)
1 pot cozy
1 Insulated mug
1 Lexan bowl
1 Lexan spoon
camp suds
pot scrubber
2 lighters
small camp towel
Personal
Knife
headlamp
small led light as backup (works best if can be clipped to a hat)
lip balm
sunglasses
camera and film
first aid kit
fishing gear
bug repellant
compass
1 trash bag
waxed parachute cord
duct tape (wrapped around trekking poles)
repair kit covering tent, thermarest and stove
shovel for cat holes
small closed cell foam pad- beats sitting on rocks and weighs 2.1oz
Hygene
Toothbrush and t-paste
medication
toilet paper
6 sterile wipes
dental floss
foot powder
camp suds also used for cleaning myself
Tent
sleeping bag
hydration bladder
1 plastic gatorade bottle (1/2 the weight of nalgene and just as indestructible) with this I carry a spare screw on lid with tiny holes punched for a shower.
I am shooting from the hip here and I pretty sure I have forgotten a few things.
Go buy a digital letter scale and begin weighing everything and I mean EVERYTHING. Don't use little nalgene containers for stuff. They weigh a lot and take up space. Labeled zip lock bags are your friend. If your can save an ounce hear or there, do it and the overall savings will be substantial.
Let me know if I can offer any additional help.
Buck
Wow, I just realized how far in the dark ages I am. Instead of making my pack weigh less, I just train with more weight so that I can carry it...
