Locking Hubs...
Whidbey Island, Wa
Was thinking about doing the manual locking hub conversion. Wanted to get feedback from those who have done it or know someone who has about their satisfaction with it.
I know that Slee makes a conversion kit, also wanted to know if there are other makers that anybody has used and pros and cons.
So, Please bring forth the wisdom that is MUD...:flipoff2:
Dave
We have 2 available here. Marks and 4wd systems. I have fitted both. mine has the Marks kit and the other I fitted to the Brother in Laws Cruiser. No real difference in the 2 kits. Both have ben in for a couple of years withut any problems
I have installed 3 kits. 2 on 80s and 1 on a 100. I am a believer in the kits although lots of folks don't understand the 2wd thing. You do need to install a whole 2wd kit along with a Center Difflock Switch, not just the hubs. This uses the CDL to lock into 4wd electrically and uses the shifter for Hi/Low.
Ok, I know I am going to get flamed fro this but here goes... does this improve mileage? If so by how much and if not then why did you do it?
I spoke at length with the guys at Slee about it, and their reasons are not geared by the fuel savings it might offer.
The real key is the minimization on wear of all the front axle parts. You spare the wear and tear on the front by completely disconnecting it from the load applied during driving.
Even if you were to remove the front drive line, you still have everthing in the front axle turning, as I understand it. The only way to stop this from occuring and the constant wear is to completely/mechanically disengage it by doing a part time conversion.
The savings in gas according to Slee, and from some other sources can be anywhere from 1-3 mpg. But this is really inconclusive.
If your doing this, generally your doing it for the other advantages.
Dave
What is the range of prices for those two kits.
What kits did you install, any differences, pros/cons...
All 3 were Slee and all were quallity parts. Its a very simple kit which includes a spool (or maybe 1/2 a spool) and the hubs. Install time was about 5 hours total on the 80s and 6-7 on the 100 because we did an axle service while it was torn down. Fuel economy is not why you will do this conversion. I got maybe 1 mpg better.
Is there any tear down involving the transfer case, I read something about the viscous coupler, but there was no link on the Slee page to their detailed info. Definately not doing it for the MPG.
