I will soon be able to get new Aisin locking hubs for the 80.
That option will be nice but I will still have to remove the drive shaft to be able to fully unlock the front diff.
That is unless there is a way to unlock the drive shaft from the t-case without removing it....
Is there such a device that you can add to your drive shaft that you can lock and unlock the drive shaft?
This should work if it would fit the 80
Front Driveshaft Disconnect
Its a Front Driveshaft Disconnect for a Hummer.
Wouldn't this be a better/cheaper than doing a part time t-case conversion?
I could care less, though.
