Hey guys had a qustion, I have a 92 fj with the semi flooting rear axle. And a friend of my has a factory locked fzj, he is going to trade it in as a cluncker to be crushed. I was thinking it should not be to hard to swap axles. Are the gear ratios the same, are they a direct swap, how hard is it to remove the wiring harness or is it easier to make a new one? Is there a computer or just a relay? Will the factor 15 inch wheels fit newer axles. I know he will lose his antilock breaks, but I assume they will still operate fine? Any help Thanks, Brad
I forgot about that. You are correct.
