In order to drive on pavement where there is not likely to be any wheel slippage, all three differentials must be unlocked. This allows the four tires to spin at different speeds as you corner, change lanes, etc. Basically, the power goes from the engine, through the transmission to the transfer case which distributes power to the front axle and rear axle. With the center diff unlocked, your in All Wheel Drive mode which allows slippage in the center differential and sends an unequal and variable percentage of power to the front and rear. With the CDL (center diff lock) locked, your sending 50% of the power to the front axle and 50% to the rear axle at all times and you are now in proper four wheel drive mode to be used only on lower traction surfaces. Each axle in turn has its own differential which slips to allow the inside tires to rotate at a slower speed (because they travel less distance) than the outside tires when turning. The "problem" for offroad applications is that the differential's ability to allow the left and right tires to turn at different speeds also allows one tire to spin out of control if it looses traction during acceleration. You've seen it before when a truck is trying to drive on a slippery surface and one rear tire spins while the other doesn't move and the truck is stuck. By locking the rear diff, you create a solid connection between the left and right tires (eliminating the ability to slip) so that you only need one of the tires to have traction and you can still move forward. The same is true for the front differential but the front diff is only lockable if the rear and center diffs are already locked. Most offroad minded LC owners value the factory option for front and rear locking differentials because it allows you to maintain forward movement in low traction situation or even if a tire is completely off the ground. Just remember, when any of the diffs are locked, you can't go around turns because you have prevented the tires from turning at different speeds and this can cause binding stress on the drive train components. I have heard that about 10% of 80 series LCs have the factory front and rear diff lock option (the dial to the left of the steering wheel).
