Locker Part Q
NB, Canada
I recently purchased a rear factory e-locker/3rd from a 96 cruiser. The 5 tooth steel piece that rides on the long spline axle and rotates in the actuator fork may have gotten misplaced by myself/shipper/seller, how is not the issue. I'm holding some hope it will be found however.... Is this a part one can purchase separately or have I basically spent like $500 on a doorstop?
Any input is appreciated.
Chris
I assume you are referring to the lock collar
41453-60011 is the PN
I suggest calling Cdan to make sure you have all the bits you need.
I called CDan, you had the right part number, they are 5 weeks away from Japan... so, what is it called and anybody have one for sale in the US?
Chris
You're talking about the dog toothed collar? You have the other bits as well I hope. The actuator assembly and the fork that moves the collar bit back and forth.
Last I checked, just that collar is ~$80. Pricey, but it's probably the strongest part of the vehicle.
Either contact who you bought it from, post in the parts wanted section, or go to a yard and try and find it.
Chris
Yes, dog toothed collar (rear axle) is what I need from a 95-97. I have EVERYTHING else required to add the lockers, some of it is already installed such as ECU, switch, dash bulbs. I'll post in the wanted section. The price has almost doubled since you last checked, even from CDan.
Thanks,
Chris
