Hello to all,
I have a 95 fzj80 with 167,000 miles on it.
I have made 7,000+ miles to it since I got it with no significant issues. It has suffered from vibrations at around 70 mph since day one, I attributed this to the tight angle the front u joint was working on due to a 2" lift installed by the first owner. I installed caster correction bushings and the angle of the u joint improved but the vibration persisted so had the tires balanced, the guy in the tireshop told me that my tires, 315 70 16, where always going to bounce a bit because they are too wide for the original alloys, had him balance them any way and the vibration problem improved but did not go away.
I decided to remove the front driveshaft to see if it was the source of the problem, and not been used to fulltime 4x4 with center diffs, I removed it and drove the truck, the vibration persisted, so I am beggining to agree with the guy from the tire shop. Anyway I have not yet reinstalled the front driveshaft and have been driving the truck daily for about 2 weeks without issue.
Today reading another thread I realized that my truck should not move with the front driveshaft removed because of the central diff, unless the VC is capable of sending enough power to the rear wheels? I tried turning the front coupler with the transmission in neutral and it does not turn freely, it tries to turn in conjuction with the rear drive shaft, I guess this means my center diff is stuck locked. I tried running it in L4 and then again in H4 but nothing happened, in L4 the difflock light comes on and in H4 it turns off just like it should.
What are the different causes for this? can it be just an electrical problem with the elocker? how can I rule out the different possibilities?
Could it be a problem with the VC instead of the center diff?
I will highly appreciate any help.
Regards
Fernando
Regards
Fernando
