Lock Right Install Question?
Altoona, Pa
My existing pinion shaft that goes through the center of the locker has flat spots on each side about an inch from each end. Is this pinion shaft okay with this locker or does it need replaced with a shaft that is round full length?
Sounds like you have a stock pinion shaft to me.
As long as the shaft is smooth and not galled up, you should be good to go!
Good luck!
-Steve
Thanks Steve for the quick reply. It is the stock pinion shaft. It seems to be in good shape. I just wanted to make sure before I bolted the cover on and filled with oil. Going back to the garage to finish. Thanks Again
