Lo-beams not working
FRASER VALLEY,BC
One headlight went out last week, then yesterday the other one. I replaced the bulbs, but they still dont work. The yellow corner lights work when I manually turn the switch (shoudnt be needed for headlights as a daytime running light module was installed when i got it). The highbeams both work, but turn off without their fuse or the relay.
I am able to get a ride to and from work tomorrow but will be without lights on tuesday, and I get off after dark. I will have to take it in if I cant figure this out and Im running short on time. Any Ideas?
recheck the bulbs if the elements for low beams got burnt out. if the bulb is ok, check the fuses and relays. if they are fine, it must be the flick switch. open it up and sand down the contacts with fine sandpaper. my rigs highbems wouldnt come on steadily. it would only come on when i flash it. so i did as i suggested to you and found out that the contacts were pitted in the flick switch
I would remove the daytime running light module, it could have failed. If the module controls the lights it would be a good idea to check if it is functioning properly. hth
