LJ78 oil cooler
You're talking a transmission oil cooler right? I've done one. Was a pretty easy install. I can digup the part number if you like...
Actually I'm going to do an engine oil cooler first. More direct contact with the parts I'm lookin to keep cool. Tranny cooler after most likely to help with the towing. Id be interested in the part number if its easy to find thanks.
Here is the trans cooler: Oil Coolers Transmission Coolers Long Tru-Cool Universal Transmission Cooler (24 Plates - 1 1/2 Thick) Oil Coolers Transmission Coolers @ CoolDirect Radiators Canada
You know the 2LTE has an engine oil cooler already which is cooled by the coolant right? So indirectly, if you keep your coolant cooler, then you are keeping your engine oil cooler. An easy way to keep your coolant cooler is to put in an auto trans oil cooler (as the auto trans is also cooled by the coolant...:)). And the auto trans dumps a lot of heat when going up hills out of lock up. Like kW of heat...o_O
