LJ 73 LV engine swap
Morristown, NJ
Hello 70 world. I am new to your world and reaching out for some some advice. I have a 1987 LJ 73LV ( 2.4 T) that I believe needs an engine swap. The truck is putting out copious amounts of smoke going down the highway and feels sluggish. Does anyone have a suggestion of what I can find here in the US as a candidate that would mate with the transmission?
I found some older posts mentioning the 22 RE if I wanted to go with a gasser.
Any input is much appreciated.
Before swapping it out you should at least do a compression test. If compression is good, I'd be looking at the fuel system or turbo seals - may just need some maintenance.
Or maybe you just want to get away from diesel completely.... Having driven 22RE and 2LT(E) vehicles, I personally much prefer the 2LT(E) - especially when tuned up a bit.
We're just finishing up swapping a Cummins R2.8 into an LJ70. It's not the cheapest solution, but bolts right up to an R151 trans and has plenty of room underhood. At 160hp and 300ft-lbs it's got a lot more pep than the 2LT which was in it. Build thread... Machito the LJ70
