- Thread starter
- #21
Just dropped the truck off at the Toyota place...many people probably think I shouldnt have, but I want to know WTF is going on with it.....
-Carl
-Carl
clogged tranny filter? The one inside under the pan) maybe a small object that temporarily clogged a fluid path internally? Then cleared out...
Im not sure if i am going to describe this right, but you kinda have to loosen the nuts up that hold the shifter in place and kinda preload the linkage so that it is all tight. So you would put it in drive, loosen everything, push the shifter forward so it is definitly and firmly in the right position (aka the red gear indicator is showing in the right place), then tighten the nuts. I put bushings in which stopped the side to side wiggle, but i have to do the aforementioned procedure to get the up and down play out.
It behooves the dealer to find it dead. Get a second opinion. And try the above suggestions, excepting maybe that last one......
Link?The 'thow into Park' trick has been discussed here before.
Link?
I can't see that doing anything but harm to the trans, but I'm willing to read what others have done.
