Light Switch
Richmond, VA
Can anyone give me a wireing diagram for the headlight switch? I have an extra one sitting in the house that may or may not be good. It has 5 prongs and I need to test it. Any help will be greatly appreaciated.
I don't have a diagram on my comp, but looking at my notes in my Haynes manual this is how it goes.
Red wire = Head light fuse
Green Red = Tail Light fuse
Green = Parking Lights
Red White = Light power --> goes to dimmer switch for Hi/Low Beam on the steering column
Red Black = Panel Light Control Switch
There is another wire that comes off the light power i think, which goes to the back of the switch which allows you to brigthen/dim the whole light system. I never hooked it back up when I rewired my rig.
Trying something;
thanks for the quick replies, i need to bench test it. and i have no wireing to attach to it. i have only 5 prongs to play with. i believe that i see what i need in planet-x's post, the upper right hand side, is there any was to inlarge that or somthing i cannot make it out. thank you all very much
You do not appear to have a e-mail option, so I guess you are SOL...
as far as me e-mailing the 'full-sized' file to you
You can if you want send me an e-mail w/an address of where to send the 909 kb sized original scan
Giving us your year might help. They aren't all the same.
Here's the headlight switch (labeled as a starter switch in the OEM manual).
Hope this helps
it is a 77, i have the diagram, i borrowed the hays manuel. But i am confused like no other, where does the + come into the light switch? i am trying to wire the extra light switch for the offroad lights. any help will be appreatied. thanks again for all of the quick posts/help
