Light issues
Rivman1243
Helena Montana
This is kicking my butt.
When I step on the brake pedal the dash and parking lights come on. I checked the tail light connections and sockets. Found the trailer light harness was scotch locked into the harness before it goes into the rear panals. The factory connection to the trailer lights was wet and corroded. So I removed the spliced trailer harness and cleaned the connector out. Next I sealed the tail light housings and holes for the trim clips on the sliding window trim.
Checked the lights all working. Checked to see if the dash and park lights came on when I stepped on the brake pedal - no dash or tail/park lights! Heck yea! Go watch some football with my dad. Get in the Cruiser to go home (it's dark out now) step on the brake pedal and they're back on! :bang: I guess I couldn't see them come on in daylight.
So here see the symptoms and things I've tried
-engine running and off- doesn't change, lights still come on
- ignition in accessory- same results
-ignition off- same results
-all the above but with the park lights on-same results
The only thing that seamed to have effect on if the dash and park lights came on was if I had the lights on, kept foot on brake, and then turned the lights off the dash and park lights would have a slight delay before coming on. Also the dash lights are not at full brightness, and I can adjust them with the dimmer. One other thing, sometimes there is a 2 or 3 second delay between stepping on the brake and the lights coming on.
Sorry for the long post and I hope it makes sense. Thanks for the help.
Curtis
Update! Got in the Cruiser after work and no extra lights coming on with the brake pedal. Now I'm really lost
Check your ground cables from the body to the frame and engine to body and engine to frame. I think there are 6 total.
It sounds like your brake lights are trying to find a ground and the dash lights are on the same circuit. (If your brake lights go out, your dash lights go out also.)
Thanks @BILT4ME ! I was able to check the ground under the center console and the right kick panel tonight. The center console ground had a piece of wire crammed into it from a PO. So I removed the wire and sanded the paint of from body.
I wasn't able to get the lights to malfunction though, so we'll see what the morning brings
Have you tried replacing your tail light bulbs? The dual-element bulbs can short out and cause this problem.
The ground point for these bulbs is the one located underneath the truck, in front of the rear crossmember.
I haven't tried replacing the brake bulbs. I have pfran 7w reverse bulbs and have been looking for a good brake led bulb. I also have led door courtesy lights, dome, and rear side marker lights.
Haven't had any problems since I posted originally. But I will get new bulbs and put them in
I forgot to follow up on this! I eventually cleaned every ground point in the electrical sys and I've never had it act up again. But it hasn't rained like it was when the lights were acting up. I also took the side panels off in the back and cleaned and checked all the connections. Basically took apart every connection I could in the rear and cleaned them. Don't know what ended up being the problem but the issue is gone.
Do you have a fsm?
Yes. Also the dash/guage lights and the light around the ignition switch would come on. The ignition switch and cigarette lights have quit working since all this started
When you cut and sealed the trailer plug, it sounds like whatever "leftover" moisture was in there finally dried out? Hoping it stays that way..... Good luck!
Update I figured out my issue I (may) have driver through a salt water puddle on the beach that was rather deep and water may have entered the cavity in which the tail light harnesses sit and caused some corrosion
I removed the lovely "scotch locks" and installed heatshrink butt connectors.
