Light install, what am I doing wrong....
Lyons CO
Picked up a set of those HID lights from Check Auto. Tapped them into the Slee harness and no go. I have had lights on there before no problem but these guys will no turn on. THen wired them up per instructions and the switch would light up red, but nothing again. I took the lights right out of the box and mounted them. Was I missing a step or do you need to hook something up in the light to make it active? It's killing me because this is a simple task.
So you are using a Slee jumper harness that has worked in the past?
Also, sounds like you used one of those cheap rocker switches supplied with the lights. If I were you I would eliminate the switch and have them turn on automatically with the high-beams. At least until you can get them working - then reattack the switch issue.
Yea, they did work. Didn't come with a switch but I used toyota ones that have worked before. I plan to spend more time on this tomorrow.
