lifted tundra pics??
lafayette, LA
Website
www.myspace.com
im lookin for an early model tundra lifted... and a little info about the kits and how you like them
How much lift are you looking for? I've got an 01 with Icons. They raised the front 2.5". Looking to add 1" rear soon.
As far as info- if you get 4WD stay away from spacers kits...if 2WD still stay away. Def. go with quality coilovers.
Also you can find more pics at tundrasolutions or socaltundras
im lookin for a little more than 2.5 i have seen a tundra that is clearin i think it was a 37 and it still had the IFS front end and everything. but yours looks awesome
is that the factory front end?
Front end?
The body is all fact. w/ trd grill deal and the suspension is just coilovers @ 2.5".
If you're looking at a 4WD you'd need a long-travel kit to lift it enough to clear that size tire without crazy CV angles.
2.5" clears 255/85-16 on mine no problem, but more lift and you have CV angle issues. If 2WD there's no end to what you can do really.
go check out SoCalTundras for everything from mild to wild.
You can run 37's w/fiberglass fenders and the right backspacing and/or a long travel kit. With the 4wd you can run them also, but again its limited lift but a ton of travel w/lt kit. Also, there are diff drop kits for the 4wd to keep your axles lined up and reduce the strain on the cv joints.
I have DH spacer lift now which is fine for clearing tires, but doesnt help with any wheeling. Im going with LT thats why I used the spacer kit till I decided which route to take. Take a look at 2008 Total Chaos Fabrication and Camburg Engineering Inc - liftkits - shocks - hella - bilstein - offroad for a good selection of Tundra specific AND useable suspension choices. Also check out Wheeler's Off Road for a good selection of mild to medium suspension choices
