Lifted my 80
Santa Cruz
Here are some pictures before and after. Sorry for the crappy cell phone pictures.
My trusty helper. You could tell she was exited about this one.
Has anyone fabbed up there own panhard bars, would it be unsafe to cut the stock bars and weld some burly tubing on to make them longer? My alignment is all messed up.
yep, its a 863J in the rear with L shocks and 420 comp coils up front.
This started as a 3-4" lift and turned into like 6" I installed the 850J coils up front first but they were way lower in front than the rear so I ordered the 5" OME comps and MAF 3" control arm drop brackets to get back some of my castor. I have some OME castor bushings too.
I also needed a longer front brake line witch I am installing today, I havent drivin it sence I put on the lift. Cant wait.
As for the panhards, I would think it would be easy to measure-cut-weld-replace, but Ill probably end up ordering some.
Next, gears and tires. Any suggestions for gear ratio with 315's and a 3fe?
4.88 should be enough if you don't have a plan on going any bigger than 35's.
I really like that color on a wagon.... oh- and ditch the rest of your flares- it looks good!
And- 5.29's. The 3FE will thank you.
