Lift
DKW
Fl, USA
I bought a truck that has an OME lift. There is no castor correction (jolts around a little at speed) and I was looking at options for this, so started off to measure what I have. Was surprised to see such a difference on each corner. Driver front 2.75”, driver rear 3.25”. Pass fr 3.25”, pass rear 3.5”. I measured from axel to fender and subtracted 20”
Are these differences unusual? There is no front or rear aftermarket bumpers or any additional weight in truck
Thanks
I could be wrong here but for your situation it seems as thought the springs are on the wrong sides. There are a couple items to consider:
The OME springs have A/B Lengths:
  • A
    • driver side
    • Longer
  • B
    • Passenger side
    • Shorter
The 80s were designed as a wedge front to
Back with the rear of the truck higher than the front so that it would settle to level when fully loaded. Spring kits are assembled to support the higher rear design. Lots of folks here call that stinkbug. Some love, some hate it.
Im sure someone more knowledgeable than I will correct me if I’m wrong. There’s also an encyclopedia grade sticky at the top.
Thanks. I didnt think of that. I guess only way to find out is to remove both fronts and measure. Will have to wait, other fj80 priorities!
Most of the time (when the coils are somewhat old) to swap them side to side. It tends to equal the stance in the front. The rear is not necessary to swap, it will even out by itself once the front is done.
I was going to just put the longer of the 2 on the DS. But if they are both worn this may not be seen in the length only? I’ll Try and put some pressure on them both and try and gauge which has most ‘spring’ left in it
