Lift Without Caster Correction
NOW in Texas
Just finished, well not really, a 3" OME lift on my 80. Didn't have time to get to the caster bushings and extended brakelines. So far truck running good on/off highway, freeway. Steering mybe a little off. Question is what problem should i expect since i don't have the caster corrections on??
Steering "heavier" than with proper caster. Steering wheel doesn't return-to-center properly when turning a corner. The worst for me, was the bizarre high-speed steering when going through long, sweeping curves at 80+ MPH with some wind and a heavy load. Down-right dangerous.
-B-
I had the same lift without correction for 8 months... The truck will dart around in high wind or if you run over an uneven shoulder you will feel the truck pull dramatically, the steering doesn't seem to correct itself so well. After going to Slee blues I am much happier with the ride as it seems more sure-foot/stable on the highway.
It may be tend to wander a little while braking, also while driving down the hwy.
For the 3" OME you may want to look up the landtank axle brackets, or the slee brackets. On my heavy front, med read, my castor is right at 1 degree positive with the ome CC bushings. I need a little more cc, with 35's, but it's fine for now.
Slee also makes a 3* bushing. It depends on what the castor measurement is now that you have the lift on.
If you put on the longer shocks, be careful "testing" it out, you may mess up your brakelines.
thanks for getting back quick, guys.
I'm gonna have to wait until next weekend to put the castor corrections on. This is my first time doing a lift. good thing a buddy was with me whose done a lift before.
Well, this thread is useless without pictures:flipoff2:
As mentioned earlier - wandering while braking. The faster you go, the harder it wants to wander. Not much fun. I have been running without cc for about two years now, but I don't see many high speed highway miles. I do not recommend running without it for any length of time.
Are you doing the caster corrections bushes yourself? If so, how are you doing it? using a press or making up your own tool?
I've seen a few sites where people have used a DIY tool from threaded rod, section of pipe, washers and nuts.
Something like this:
Fair enough it's not an 80 series caster bushing but I'm wondering if this would work here as well?
Anyway, here's some links:
Sportruck.com - How To: Polyurethane Suspension
Homebrew Volvo Trailing Arm Bushing Tool
Are you running J-springs & L-shocks or The 2.5" med or hd's? With the J's,I have a 1'' spacer on the front.The Slee plates are great,no vibrations,really smooth responsive steering.
If you have the 2.5" med or hds,I would go with the Ome CC bushings.
