Lift Question
6 months here, 6 months there
I have a 94 landcruiser that I installed a MAF supplied OME 3" lift on recently. 1" spacers were installed all around bringing this lift to 4". After lifting my rear axle was noticeably shifted to the passenger side of the vehicle so a rear panhard rod drop bracket was ordered and installed as a fix.
The rear axle is still shifted to the passenger side although the bracket seems to have helped a little. Drivability isnt affected but it looks odd form behind and i am concerned about rubbing when i throw on some larger tires. Other than the lift this truck is stock with no additional weight from armor,bumpers,winches,roof racks, etc..
Could that be an aggravating factor and I am achieving more lift than 4"? Would additional weight such as fr/rear bumpers and roof rack help with the misalignment?
I am not a crawler and prefer expedition style offroading, taking the girls out to the mountains so i would like to work with the existing bumpers. Is the SLEE panhard adjuster a good fix for this? I am out of state so I cant provide any measurements but the offset is not extreme, maybe an inch max. Any feedback is appreciated especially if youve encountered this on your rig.
Thanks
If you armor your truck, you will "lose" lift and the axle will shift back as the angles change.
It's important to know how much lift you want for the amount of armor you have. What may be one persons 3"lift could be another persons 1" lift (expedition style truck) or another persons 5" lift (unarmored).
You can go with an adjustable rear panhard rod to allow you to change the angles as you add armor. If you're planning on doing your build in stages, this isn't a bad idea.
where did you get the drop bracket from, This won't do anything for centering the axle. You have to eventually run an adjustable panhard for the front and rear in order to fix this. I'm telling you this because of first hand experience. I also have the drop down bracket but it didn't help with centering the axle. I went and purchased slee's adjustable panhards and this put my axles in the sweet spot. I read on another post, someone bought the same bracket as me but what he did was grind some of the metal off so that he can install it the other way. This he claims to have centered his axle. I didn't want to mess with it so I can't tell you if it works or not I just didn't want to deal with it so I chose to buy the adjustable instead. I'm running both without any issues and my truck drives great. here is the post on the MAF unit I have.
https://forum.ih8mud.com/80-series-tech/74978-maf-rear-drop-bracket-issue.html
Checked that link out. I dont believe my bracket has been modified from 4+ or MAF. When I get back Ill check it out and do some grinding if necessary. Slees out of the rear panhard adjusters right now anywhoo.
