Lift question
I purchased a 95 land cruiser and I love it. First for me, coming from always being a Jeep guy. Ut came with an OME lift and it's older so I can't tell what size it has. No paint to see on coil springs or anything. Previous owner didn't out on and me isn't very good with cars(his wife made him sell it) lol. Is there anyway to measure to tell what size lift they put on it? Or anything to look for to see what size is on it?
Im in the process of performing all the maintenance that wasn't done at all and might update the shocks and springs. Any help would be much appreciated.
The best pics of the springs you can post would help those in the know....
Any label looking tags on the springs?
What size tires?
I'm pretty sure that 2.5" is one of the most common OME lifts.
I put pictures of spring and shock that I could get. No tags on the coil springs, and it's 295 tires on it
Ah...my bad. Not sure why they didn't show earlier.
Oye! Those look like s***e perfectly replaceable. lol
What is your plan were someone to identify them?
I don't want any shorter of a lift so if it's like 3or 3.5" I want to stay there. And I want to make sure all modifications are done to help with handling. It tracks bad ATM. I don't think they did any caster adjustment, no plates and the bushings just look like standard black bushings. Not sure if that my problem or not
Ok, you're good then. OME's "2.5" lift is closer to 3.5" in my experience. But then I'm running the heavys in the rear. And black bushings...they may be OEM, either original or recently replaced. If you decide to replace them, go with OEM. All aftermarket bushes are poop.
