Level or not level?
Installing a 5.0 Ford motor in a 71 40. My question is should the motor be dead on level side to side? Are your Chevy motors dead level?
I welded the motor mounts in while attached to motor, trans and t-case. After pulling the asembly the passenger side mount is 3/4 of an inch lower and 1/2 inch rear of the drivers side. (as measure from the rear of the shock towers to center of mount) Driveshaft placement is as straight from the t-case to axle as I could determine by sight.
Frame is level. Angle finder on top of maifold showed "0" degrees side to side and 5 degrees rear tilt while welding mounts.
Knowing that a motor will encounter off kilter position during operation should I be concerned about static placement?
Can't answer specific to a 40, but in general as long as transmission/transfercase shift linkages still line up you're fine. Some vehicles like Unimog 404s are intentionally tilted from the factory so the head will clear the in-cab motor cover.
Thanks for the reply! Started thinking I had FUBARed my new mounts and would have to start over.:beer:
UMMMMM close but no. The question is not addressed in this thread, thanks for the help though. My only concern was the orientation of the motor on an "X" axis during static placement.
Nice pics of your work though!
