lengthening driveline question.
1973 FJ40
I am flipping my front springs tomorrow and will need to lengthen my front D/L. I have an extra spare trail shaft that I will use for the increased portion. Since it is a front shaft and only used in 4 low at trail speeds, I am not too worried about vibration. To do this, I was going to cut my existing shaft in half( or is it better to do at the axle end?, cut the needed amount out of my spare and put inbetween the origional cut shaft. I was going to put a smaller diameter tube inside the shaft as a sleeve with holes drilled to weld up for strength along with the welds around the seperate pieces.
Does anyone know what size inner tube I would need for the sleeve since it is a conversion between metric and standard? What size, thickess, and type should I use?
How much spline should I see sitting at ride hight (4" SUA that sits level to my rear SOA with stock flat springs) for proper extension and compression of the drive shaft while flexing?
As long as I keep the existing tube in the exact same alignment, vibration should be at a minimum. I also read the article from TLCA about heating and shrinking the tubs to help slide them together for prewelding. Any suggestions other than the questions above?
Thanks, Slickrock.
it would be better to cut it at the yoke ends/slip joint of the shaft and reweld a whole new section in, that way yu can just spin it up in a laythe to weld and it will be a stronger weld than cutting it in the middle (also you will not have to sleve the shaft). you should be able to get a shaft of simular OD dimentions from a wrecking yard for cheap to use as the donor shaft. as you stated its only going to be low speeds so balancing will not be nessasary but try to get it pretty close in "phase" when welding
hope this helps
cheers
EDIT:- if you find that it does vibrate a little too much, get a hose clamp that fits the diameter of the shaft, fine tune the position of it until vibration has gone or decreased.......very time consuming but it works a treat as a balancing weight
1973 FJ40
Thanks, Slickrock.
My suggestion; get this done right at at a driveline shop. Just me, but this isn't really the place to save $75. One other issue with Toyota driveshaft tubing is that it is crazy thin. The driveline shop can replace with a heavier wall tubing that will be less likely to get dented on the trail. I do agree that you don't need to pay the $25 to get the front shaft balanced.
The idea of butt welding thin wall tubing and being left with a usable driveshaft is not a good one.
And one other thing. With a Toyota slip joint, you won't see any spline showing. Assuming you go to a drive line shop, all you need to do is tell them the flange to flange distance, and they will set the length correctly.
Thanks for the response and I thought about that. I thought about that and found a better option. It looks like it can be easier than I thought. I can get a larger diameter tube from Napa and following TLCA's latest article: TLCA : Toyota Trails, Jan/Feb 2008 This is the plan at this point and I can use my spare shaft as a practice round.
Anyone know the correct length from U-Joint to U-joint of an SOA front flipped driveline off hand for propper extended and compressed lenghts?
Driveline service in Fresno did both of mine for about $100 and they do work for Marlin as well, ..............Hard to beat!
Hey Jerome. The post about the info from hard core was perfect and everythingI need to know. I am going to give it a try first as a learning experience. If it doesn't work, I'll call them.
