left rear drum locks up
1991 fj 80.The rear left brake drum is locking up when brake is applied.Any suggestions why?
Most often cause is fluid leakage, from ether the wheel cylinder or axle seal.
Thanks for the reply.I noticed burning smell coming from wheel last spring.I pulled drum and cleaned things up.I read on here somewhere that a clogged diff. breather could force fluid out.I pulled drum a couple times over summer.It did not seem to be leaking anymore.Do you think build up on shoes is causing wheel to lock up.Should I replace shoes and clean up inside of drum.
