Led turn signals
Here are two vendors I found via a quick Google. I did not realize LEDs have dropped so much in price recently, I may start up upgrade my lights. I am not sure what you mean when you say you want a turn signal and not a two wire running light. You either install the light on the blinker circuit or the running light circuit. What makes it blink is the flasher, which you will need to install an electronic one to make the LEDs blink properly.
http://www.mesa4x4.com/dynamic/part_details.asp?part_num=LD-1277A
http://www.superbrightleds.com/cgi-bin/store/commerce.cgi?product=TRUCK&cart_id=5918507.1693
Ive found the side marker lights (2 wire ) but cant find a turn signal (3 wire) 2-2.5 in lled amber light. Can I make a 2 wire led work for front turn signals with one of those brake contollers?
Got it, you want a marker/flasher in amber. Let me check my Trucklite catalog. I would install an electronic flasher before I installed resistors or brake controllers to get my LEDs to work. I went with LEDs in my minitruck and used an electronic flasher replacement to get them to blink. The old relay style did not work for me.
Update: I am not sure what you want exists in the size you want. I can find larger 4" LED amber marker/flashers and other shapes and sizes but not 2". Good Luck on your hunt!
