led trouble
Santa Rosa, CA
Not the kind of trouble you think.
My son and I hooked up a very cheap pair of lights on our new side by side. I got a set of switches that have status LEDs. When I wire it straight through the switch it works. When I wire it through the LED, the LED works, but the relay for the lights won't trigger and the lights don't go on.
What's going on?
Peter
You can't wire it 'through' the LED - that pin is just to light up the LED - you'll get minimal current flow (whatever the LED + the internal resistor) allows to flow - not enough to fire the relay, but enough to conduct a little through the relay for the LED to light.
EXACTLY what kind of switch is it? Does it have 3 lugs (2 for the switch + 1 for the LED). You need to know if the LED lug is ground or +12V to light the LED (the other 'end' of the LED will go to a resistor to limit current for the LED and then to one of the switch lugs.
Pictures would help us... and a bit more info regarding the switch
cheers,
george.
It's a two lug toggle switch and two lead LED. So, instead of wiring it through. I take the LED separately to power and let the switch supply it's ground when it grounds the lights - right?
Yes, use the 2 lugs as the switch for your relay ground side switch. Switching the ground side of the relay, means you wire the +12V to your LED+ and the switched ground to your LED-. Then the LED lights only when the switch provides ground the LED and the relay. Other side of the relay +12V goes to a fuse protected +12V source.
cheers,
george.
