- Joined
- May 19, 2008
- Threads
- 61
- Messages
- 368
Hey everyone.
I had a signal light go out on the front passanger side (right side). I noted this when using the signal and the rapid flash. So, I pulled the front fender signal, saw that it was an LED 1100 light and looked burnt..(I was surprised it was an LED light and figured that the person that owned the vehicle before me converted it from the standard bulb to a LED.) I replaced the fender bulb and it still didn't work. I turned on the signal again and noticed it was the front bumper bulb, I pulled it out and it was rusted.
I have two questions here now:
1) Aren't the front fender amber corner lights suppose to act as signal indicators and not just marker lights? As you can see from the picture the left front fender light is acting as a signal, and the left front (drivers side also) is acting as just a marker light and is not flashing. This is the case for both sides. Is it the type of LED 1100 bulb that is not allowing the fender amber lights to work as a signal light assuming that is their function?
2) Anyone have an adapter for the bottom front signal in the fender they want to sell? I know...I'll check the classifieds section too..what's the technical part name for the wiring harness?? I could use some new front lenses too...
