LED Rear Tail Lights Install
Seattle
Hello everyone. I am the proud new owner of a '72 FJ40! It has had a lot of interesting additions/mods that I'm more or less putting back to stock. I just purchased some rear tail lights to put on the rear bumper...
(Pair of Early Toyota FJ40 Land Cruiser LED Tail Lights Lamps Rear Turn Signal | eBay)
It appears as though the correct holes are on the bumper because the bracket holes line up perfectly. But the very edge of the bumpers slightly protrude into the bracket openings where the lighting assembly is supposed to be inserted. As I'm a new FJ40, I'm chalking this up to user error. What am I missing? Did I purchase incorrectly sized lights for my '72?
Thanks in advance for all your help.
u need the bigger stock brackets
Had the same problem when I installed LED rear lights. All I did was mark the area and grind it out.
Thanks for the replies.
Where can I find the bigger stock brackets? All the ones I've found appear to be the same size as the ones I bought.
I have run into the 2 different size this before on a 1964 fj40 , i sourced the large ones and the big lamps too at SOR.com
i know u have LED lamps now , they will kick as# !
here was my set up with my reproduction AUSSIE spec rear turn signal lamps as well
View attachment 1779370 View attachment 1779371 View attachment 1779372 View attachment 1779373 View attachment 1779374
Thanks. I'll take a look on SOR again.
Love the Aussie turn signal lamps! Thanks for the pics.
While I have some of you online right now... do you have a preferred suspension kit? I'm going to replace mine next month. And please pardon the basic questions. I am brand new to the FJ40 world.
the ONLY one i go with is Old MAN EMU
