LED Headlights for FJ40 and Early Mini-Truck
Palo Alto, CA
Set of 2 plug and play LED headlights for your Land Cruiser FJ40. Also fits '79 to '82 Toyota mini-truck / pick-up with round headlights.
Two types are offered, one with DRL (Daytime Running Lights) and one without. The DRL version has more functions, while the non-DRL version is quicker to install and lower cost. Both versions have the same high quality CREE chips.
Features:
  • Bright white light - 6000K color
  • Instant on
  • 50,000+ hours life span - That's 5.7 years
  • IP67 rating - Tested for 1 meter of water immersion
  • Low energy consumption - If you forget to turn off your lights, it will be hours before the battery is drained
  • Works for cars with either 12v or 24v systems - Has operating voltage range of 9 to 32 volts
  • U.S. DOT and European E-Mark compliant
  • Beam is not sided. Fits either LHD or RHD vehicles
  • High quality, jewel-like appearance. On low beam, top half of the light is illuminated. On high beam, both top and bottom portions are illuminated. High beam will literally create daylight ahead of you, which is ideal for off-road situations.
Easy installation. Simply plug in the headlight to the original H4 connectors.
Price (For a set of 2):
  • Non-DRL version: $129 + shipping
  • DRL verion: $145 + shipping
You can purchase at: www.cityracerllc.com
Photos to follow.
Non- DRL version:
DRL version (cotinued):
Notes:
  • The DRL power wire needs to tap into an ACC power source so that it will turn on automatically when the car is started.
  • Common ACC sources include the Vacuum Switching Valve (as shown in the photo) or the ACC terminal in the fuse box.
  • On the FJ40, the turn signal wire from the harness is green/black on the left side, and green/yellow on the right side
View attachment 1309449 View attachment 1309450 View attachment 1309451 View attachment 1309452
Notes:
Notes:
Good evening Racer5,
Do you have the LED with the DRL available for purchase. I am looking for the 7"round for a 1974 FJ40. I live in Sonoma County. How quickly could I recieve them?
Thank you, Brian
