Leaping Deers FJ45pb
More 45 cage pix
couple more pix from tonite
just about done
have not tied down behind dash Randy, could be done, usually just go straight to floor...trying to maximize room here, the 45 is tight
my truck's been over 4-5 times with this design FWIW
there are full 3/16 backing plates back there tho
sorry for the bad light
Are you going to paint the inside of the tub while it is all apart? The body looks like it is in pretty good shape, except for a little bit of surface rust: perfect candidate for Rhino Line:D
Cheers,
Josh
Yes - very nice work :beer:
And thanks for lots of pics
finished up
buckets mounted
Thanks Jason!
I like the integration of the upper seat belt anchor into the roll bar. What was involved in mounting the bucket seats? I have a set that I'm wanting to put in my 78 FJ45, but I'm told that the seats are shaped differently from the back of the bench seat and don't fit properly against the back wall without some modification. And moving the seat mounts forward only move the driver closer to the steering wheel. What did you goes do to get those seats in there without compromising driving position?
down the back near the seats how did u mount it to the floor??? can u remove the cage when you take the roof of ???
there is a 1/4 inch thick plate there, bolted in, fully removable
seat are different, p/u seats mounts are narrower
removed sliding mech from bottom of seats and mounted on cross bars which were welded to original drivers mounts over tank
pass side made mounts out of old 40 legs and remains of sliding mech that was removed....
Build him a special doggy seat in the bed.
as always, amazing work kina:clap:
Jason that 45 is just plain bad ass
4" lift maybe:D
