Lean after OME install
Charlotte, NC
Just installed OME 850J/863 on my 97. Now have a very heavy lean to the drivers front. Its about 1.5" low. Any Ideas?
From Sleeoffroad.com:
6. The springs have white tabs on them with the spring identification, for example OME850 DS. Make sure that you have the both DS and PS springs for both the front and the rear.
7. IMPORTANT. In the US, with left hand drive vehicles, we install the DS springs on the PS and visa versa. The springs are labelled for the right hand drive vehicles. If you can not locate the labels, or you have used springs, make sure you mark the springs that you remove from your vehicle and match long with the long and the short with the short springs.
Unless the springs are labeled (or printed on the coil) R/H and L/H, then you install them as per the label.
Lately some springs are labeled A and B. A is for Australian driver side, so in the US this should go on the passenger side and B should go on the driver side.
Also, here is a thread with some other folks experiences
Awesome! Thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
swap your front springs to level it out. :cheers:
