Leaky Leaky
Altadena, CA
Been getting lots of rain lately, and now my front right footwell carpets are soaked.
At first, a while back, i was thinking my heater core might be going, but it definitely isn't coolant.
Is there any danger in leaving my climate control in "VENT"? Are there drain holes or tubes in the hood vents that could be plugged with debris or even painted over?
I used to have an old volvo in that had major leaks. one issue was the main vent under the windshield had vents that regulated fresh air flow. they were rusted open, so everytime it rained or i washed it with out covering that vent, water rained down below....
thanks for any info or advice! - TSH
I have the same problem on driver side.....was thinking window seal.
I had one spot that was staying wet when it rained that turned out to be a crack in my rain gutter that was leaking into the A pillar and onto my floorboard. Sealed it and solved it.
leaky no more
I have just finished repairing mine, keep in mind i'm in aus so most things are in reverse. I found a hole just above a/c fan and behind windscreen wiper motor mount caused by leaves accumulating in the narrow drain area.
There is also an inspection plate in the same area of firewall/cowl on the opposite side where your wiper motor maybe mounted?
I had to remove bonnet hinge also where it recesses into the cowl, this part blocked the leaves and water from escaping out through the drain hole.
Grant
ahhhh ok....i'll have to check that out....thanks GT!
before it was just a little moisture....and that made me think of a coolant/heater leak.
but since we've had so much rain lately, and the fact that both carpets are completely soaked...it's gotta be something bigger.
so i got in behind the firewall access door on the driver's side. muck, and leaves galore! picked it all out and washed it with a high pressure hose. then i moved to the access behind the wiper motor and it was even worse. there were probably 3 to 4 handfulls of mud, pine needles and leaves completely clogging the drainage route. flushed it all out with the same high pressure hose. seems to be ok now.
makes sense that that side was leaking more due to the fresh air intake screen being on that side.
*on both sides, it was much easier to get everything out by removing the hood hinges.
Grant
Hey Grant,
So where is the drain hole? I pulled the cover on the left (US driver's side) and cleaned out the pine needles, but I couldn't feel far enough inside to ID the drain hole.
Tomorrow I'm thinking about pulling the wiper motor plate off to check for more debris on the passenger side.
Bryan
Were is the firewall acess door located at exactly? Thinking that might be
the source of my soggy carpet as well.
I posted to your other thread. The access panels are the three black panels along the top of the firewall. Each one is held on by, I think, two bolts (except the wiper motor one, that has more).
Hey Grant,
Bryan
When looking through the inspection hole the drains are at the lowest outer part of the panel draining with gravity in between the panel and fender/guard if that makes sense? Hard to see without some contortion!
I can maybe take a pic later if you really really need it.
This is a pic of the inspection plates, windscreen wiper motor on the left circled.
This is not my car i stole the pic from here. Adventure Motors Costa Rica
