Leaky heater hose?
Hey Guys,
I was just messing around under the hood of my 94' and noticed a couple of dry pink drops on the side of the engine block. Closer inspection indicates that there is a small leak coming from a heater hose on the PS of the engine. This hose or series of hoses comes from the fire wall and down the PS of the engine. I'm guessing this goes to the heater system?
Anyway, the sections of hose are relatively short. Each section is about 4-6" long. I think only one is leaking, but I don't have time to get to a dealer or wait for parts in the mail before I need to drive this again. Is there a quick short term fix until I can do it right?
Anyone know what size ID this hose is and where I can look for a temporary replacement? Any recommendations on temporary clamps?
How much coolant should I expect to lose if only removing the short sections toward the rear of engine near fire wall?
Thanks,
Chris
Technically the coolant in those hoses is coming from the heaters and going back into the engine, but that's just semantics.
If it's only the odd drop now and again I'd drive it and keep an eye on the coolant level while you wait for the right parts to come in. One of those hoses has a funky bend in it that would be hard to duplicate with regular hose, and one of them has an odd inner diameter that is hard to find.
Either way, you shouldn't lose much coolant when you take them off.
If you are talking about the run with the "T" to the left of the horseshoe, it is sold as an assembled kit, part # 87209-60290 or in 3 parts, 87246B (front), 87228C (T), and 87246A, (rear). Now is a good time to buy the constant torque hose clamps. If you are nowhere near a NAPA then the McMaster Carr part # is 54205K11, phone # is (630)-833-0300 and of course they take credit card. ;)
