Leaky Cruiser
Mt Juliet, TN
Help, I have searched and tried the obvious remedies to fix a wet front passenger side floorboard.
I cleaned the sunroof drains and had the autoglass replacement guy come look at it. He said there was no evidence of a windshield leak from what he could tell. I cannot find the source of the leak either.
I have pulled the carpet back trying to find where the water might be coming in at, but there is just no trail leading in from anywhere. The headliner isn't showing signs of being wet. I am getting aggravated looking for this ghost.
Even though the windshield guy said it wasn't the glass leaking I'm not sold. It is not the original glass and when I drive with the heat on the lower corner on the passenger side is the place with the worst fog.
Someone please help me figure out my leak.
Kevin
I thought about that, but I only drive it a couple days a week. So, I dried everything out and left it to sit through a rainstorm. When I checked the carpet was wet and the trough for the wiring harness in the door jamb had an inch of water in it.
However, I did inspect that area for any sign of water and couldn't find any. (This was before my rainstorm test.)
Its the sunroof drains. They seem to be fine when water is poured down them but if you really give it a lot the system will back up and start leaking at the top of the a-pillar. From there is travels down the a-pillar and fills up the floor board drain area.
What i did to make sure it was this is get the cruiser at a forward rake then pour lots of water into the sunroof drains, i used two gallons before it started backing up. Oly probelm is after i reamed the drains and outlets its still not draing fast enough so the only conclusion i can think of now is the hose is pinched....f'in headache
Those Mysterious Leaks
As a new 80 owner, I'll add another twist to these wet sagas.
I quickly found MUD and the amazing resource it is for solving problems and learning the inside scoop on this Swiss Army knife of vehicles. The wet PS footboard was something I discovered even before I bought what is now known by my wife and I as The Sacred Cow.
I'd taken it for a spin at the car lot after an extensive once over. I came home with concerns, including the soaking wet floor on the passenger side. I went online and found MUD. OK, it's a plugged moonroof drain, no problem, I can deal with that, along with a few other issues. My wife and I buy it. I take it home to clean it up.
BTW, I used a stainless steel cable to clear my drain. It was around the garage as a spare for my garage door, so it's not a big one, maybe 3/32"? I've seen other recommendations as a tool for this, but the SS cable worked great, as it doesn't kink, is heavy, and slides right down the tube. I highly recommend it for this task.
There was a distinct blockage on the PS front drain about two inches from the bottom of the tube, which ends inside the rocker panel. I popped through it with the cable. Problem solved! I thought.
After taking care of it and the issues I could deal with, I took the Cow to the local dealer for other things that needed their attention. I like working on my stuff, but the body -- my body, not its -- just isn't what it used to be when I owned my FJ55 three decades ago. Someone totaled their Pacer on 55's backend; the Pig was OK, but it trashed my neck and things have been nick and tuck with the spine ever since. But, I digress, other than there is a LC-related reason for buying someone's else's wrenching skills.
While the Cow sat at the dealership waiting for parts, we had several inches of rain. I picked it up, it's driving like new and I'm a happy camper, EXCEPT the PS floor is soaked again. AARGH!!!
So I'm thinking it's the windshield! I do some more research here. The front glass I have is not original, although the rest is, so I'm thinking bad replacement maybe? I'm also thinking to gather more data this time, though. Why?
Well, in the meantime, I discovered I wasn't quite competent about operating the moonroof. I'd close it, give it the bump past the 3/4 closed position, and seal it up. I thought. Problem was I wasn't holding the button long enough so that the back end of the panel would RISE up to fully seal the opening.
Yes, you need to remember to check the back end of the moonroof so that it rises up and fully closes the opening. I've never had such a fancy ride, but it will sure enough leak through the opening created if you don't fully close it. If you leave that pane looking like its OK and level from the inside, it will allow a lot of water to enter in a heavy downpour even if things are otherwise working OK the moonroof.
Or so it seems. I still need to fully confirm that everything's OK now, but this is something a newbie like me thought might be useful to pass along. Sometimes it's not a mechanical defect at all, but a mental defect.:doh:
Mike
