Hey guys, a little over my first year of ownership of my 120k mile 2005 LX470, and while i love this truck it definitely takes a good amount of work to maintain it after beating it offroad.
My center diff pinion seal on the front driveline started leaking maybe 2 months ago, and i put some AT205 in it which actually stopped the leak. After my most recent trips of azusa/big bear where i wheeled hard, went through a ton of mud and puddles and absolutely caked the underside of the truck, the same seal started leaking again, but this time badly, enough to leave a puddle on the driveway and a huge mess underneath.
I'm going to pull the case, change the seal, maybe bearings, maybe some OD/UD gears, but i'm a little off-put by this given the truck has such low miles and was church driven before i bought it. I should add, i did make sure the breather wasn't clogged.
Is it common for mud to tear up those seals, or is this a one-off. If i replace the seal and continue to drive the truck in water and mud, is there a good chance dirt will get up in it and cause it to leak again, or will i be good for awhile? Should i replace the rear seal as well while the t-case is out of the truck? Any recommended way to protect the seals in the future when wheeling hard in mud/snow/dirt
