Leaking Winsheild
Winchester, OR 97495
New to MUD site & 94 LC with Lockers. When it rains the passenger side floor is wet. The winsheild was replaced before I purchused the LC. With the water hose it apears to be leaking in the lower corner. Whats the best fix? Also I greased the front nuckles & an now the the dif level is over full after a couple trips. The front dif makes a low howling winie noise under power & is quite when coasting. It apears the grease has mixed with the dif lube. Do I need to repair now or do I have some time?
when the w/s was replaced they should have replaced the rubber moulding. as per the service manual
Which also includes urethane between the frame and gasket, and between the glass and gasket. This is a must.
You could try running urethane between the glass and gasket but I'm not so sure how well it will seal without installing it that way. The urethane between the frame and gasket is applied after the window is installed so you should be ok sealing that after the fact.
Did you actually see the water seeping at the corner of the windshield? I initially thought my windshield was leaking too because of the wet floor until I found out (from Mud) that the sunroof drains are known for clogging up. I ran air through the sunroof drains and it was fixed.
Just something to think about.
Salue
^ they are located in the front corners of the sunroof. Just open it and you will see them. After you blow them out make sure the drains in the bottom of the rocker panels, iirc there are 3, are clear also. I have been battling this issue for weeks. Now that I got the sunroof cleared up I can see that my windshield is leaking into the pass floor and the sunroof was leaking into the drivers. Hopefully the windshield will be the last leaking issue I have:crybaby:
Even if you have the original windshield, it seems the urethane dries out over time and will develop a leak. This also happens to the rear window which will cause rust. Even worse is a new windshield without urethane. I'm starting to think Mr T did a bad job of designing the windows on the 80.
Well it looks like Im the newest victim of the lower rhd corner windshield leak.
After a little searching it seems to be a regular problem , same spot same indications.
My question is , has any one had any luck just sealing this or did you have to go full blown new windshield and gasket?
If you sealed it was a pro job or diy?
thanks,
ken
thanks,
ken
I had the same problem. I took my windshield to the dealer and had them take out the original windshield, and reinstall it and seal it. It cost me about $95.00. My leak has gone away. They will tell you that the windshield may break when they take it out, but in my case it didn't.
I don't think this is something you can just put a little pooky on there and fix or have it last if you did happen to hit the right spot. Water can get in one area and run until if finds the path of least resistance. My recommendation, it take is somewhere, have it fixed right, and have peace of mind. You will spend more time and energy chasing this than it is worth. Especially for $95.00.
Just my 2 cents.
Well my windshield I replaced about a year ago because it was so pitted and sand blasted. Today we spent the entire day in the rain (its normally garaged when not in use) AND THE WINDSHIELD LEAKED!!!!!
I have no interest in calling dealer though but in this case...maybe. :meh:
FWIW, there is a silicone sealant for windshields you can get most places that is very runny and flows into spots unlike the regular stuff. Worked for my leak at the top of the glass, it was due mostly to the PO running the satellite antenna in the rubber and no sealant up there.
HTH
