leaking "rear wheel" - real time help
Los Angeles, California
Website
forum.ih8mud.com
i am on a trip, my "rear wheel" started leaking oil. before i start tearing into it i want to ask for your opinion. what do you think is leaking the gasket or the seal. i went to Jiffy Lube to check my rear differential oil and they told me it is full and don't need any refill. i have been driving it for 3 days this way. i have another 5 days of driving. here is the picture of the tire. thank
I drove mine like that way longer that I want to admit. Eventually did the seal kit for the rears. Pretty straight forward easy job.
thank you i will tighten the bolts around the gasket and wait till i get home. i have disk brakes i will also check around my brakes....thanks for the peace of mind.
Different vehicle... Same situation
My Dodge Ram ate rear axle seals for about 3 weeks straight Until I found the problem
What did the problem end up being?
I think the idea is to let it ride for now. Another option would be to fill with a heavier weight lube if you don't have something like 140w in there already. Might check the specs, but I think should be OK to help get to a better spot to manage the repair.
BTW, love that rig.:clap: Living the life I wish I could see past work, bills, and dull surroundings.
My problem was X2...
I missed a razor sharp burr right where the seal met the axle.
The factory seal was made a little different, it was thicker in width, and had a inner, and outer sealing lip. No matter where I set the aftermarket seal it leaked!
Buy factory seals!!
i just took a closer look, one of the stud is stripped at the nut. i will replace the stud and the nut and keep going, also will tighten the other nuts.
