Leaking...please help
Every day it rains, I get into my 1995 80 and the carpet is wet along the edge of the carpet where it ends at the door. I pull up the carpet and there is a small puddle under the carpet right at the door. My truck is perpetually damp and stinky.
It appears the rain is leaking in through the door seal somehow. Is this a common problem? What is the fix? Any info would be helpful.
Thank you,
My first thoughts go to the windshield ie: was it ever replaced (and not sealed properly)? Very common for the installers to cut corners and not seal it up properly.
Also, sunroof drains?
Other thought; have the door panels ever been off? been in an accident? Often when a yahoo tears into a door panel ie: to fix a window,etc, they forget to put the plastic sheet back in and/or do not properly glue it back in place.
Could possibly be one of the door seals, but if they were that bad, I would think that you would be getting a lot of wind noise; are both the door and door/body frame seals present?
g
Hi Scott, I'm sorry to hear you're having water leak into the truck (this was my old truck). Hmm, the only thing I could think of is that I once noticed that the weatherstrip seal was either loose or slightly ripped on the driver's side. I never had an issue mind you I owned it during spring and summer months. I'm not sure if this is what is causing it. Man I miss that thing, you know with all this snow and all....
Crochunter
I do have a possible solution to your leak. I bought my 80 a couple of years ago and soon noticed the same problem you are describing soon after a heavy rain. What I discovered is with the moonroof opened there is a small drain hole in the forward corner. It was plugged with dirt and when I cleaned it out the problem went away. Hope this helps! Have a great Cruiser Day!!
