so i found this today any thoughts
I opened it and it was dirty as **** lol should i clean it maybe replace the plastic ... it’s not water proof lolAutomatic Corrosion Inhibitor System appears to be functioning normally.
Not sure what the problem is....
If you would like to turn off the ACIS, look into changing the rear main seal and/or arch seal on oil pan.
You will find that it is much cheaper to refill the ACIS reservoir, and monitor its fill level over time, than to change the rear main seal.
But seriously, its normal on older trucks. Be glad you're not driving a Land Rover, thier ACIS has no time delay and works fine from day one.
