Leaking load sensing valve?
Hello. Have a '96 FZJ80. Losing brake fluid. Checked lines and they seem to be fine. I did notice that the load sensing valve boot was full of brake fluid. Figured this is not right. Correct? I removed the boot and when pumping brake there was fluid dripping from the valve. Can the valve be rebuilt or should it just be replaced? Thanks
Replace it.
Replace it.
Times Two. IIRR, nothing on the LSPV including the bleed screw is available separately, time to feed Dan's dogs. :cheers:
