Leaking front grease hub
Memphis, TN
I just bought a 94 LC with 188,000 miles and the DS grease hub is leaking grease and slinging it onto the wheel. The wheel is hot to the touch after driving. It looks like the rotors and brakes were recently replaced. Any ideas what might be causing this leak? When I removed the grease hub, I noticed that it was slightly deformed, like someone had previously pried it off and roughed the inside lip of the cap. Could this be the cause of the leak.
I got a great dela on this cruiser and look forward to getting ideas from the experts on this site for mods.
Thanks in advance for the help.
Grease slinger
I just bought a 94 LC with 188,000 miles and the DS grease hub is leaking grease and slinging it onto the wheel. /
Inside or outside of the wheel. Pic would help. Suspect if brake and rotor replaced PO did not replace gaskets????? Someone with a alot more knowlegdable than I will respond soon Howdy.................:flipoff2: (salute)
Congrats on the purchase and new obsession:clap:
Most likely your inner axle seal is leaking. If you look on the FAQ it will explain it better than I, but basically the innermost seal keeps the gear oil from mixing with the hub grease and vice versa. Once that seal goes bad, which they do, then you get a nasty mixture of grease and gear oil. It is a good idea to fix it before it gets to a point where it wears your birfield joint out. Its fairly straightforward in the FAQ. Good luck and congrats.
Welcome.
Grasshopper,
The answers you seek can all be found here.
Also, check out the club forums for someone near you that will probably be very willing to help you out.
Where are you located?
Dave
Thanks for the advice. It looks like I have some front axle work to do. Does anyone have the link for the seal kits referred to above.
Thanks
