Leaking front diff
South Jordan, UT
Just got back from a 3-day weekend trip into the Maze area of Canyonlands. Lots and lots of driving, mild wheeling, plenty of high-speed rallying. The 80 performed flawlessly as usual, except that my front diff started spewing lube on the highway during the drive home.
I could smell the gear lube on the highway, pulled off, and found the entire underside of my truck glistening wet and oily. Visible dripping from the front housing. Looks like it's leaking from where the third mates with the housing.
Drove home. Small puddle (maybe an ounce) under the front diff this morning. Took 5 or 6 pumps of oil to top off the diff.
Anyway,
Does this leak sound like normal wear and tear, and just needs a new gasket? I have not had the front third off since I have owned the truck (from ~100k to its current 182k miles). Are the symptoms a sign of a larger problem?
Is there a gasket? RTV? Both?
Thanks for your time.
Ryan
Generally, all you need to do it put a wrench on each of the bolts. You'll find some loose, so just snug them up to the proper torque and I'd bet you're done.
DougM
This happened to me, and I did as Doug suggested and it stopped leaking there but then started coming out the pinion seal area. I found out that all it was was a plugged up axle vent. Pulled the old plugged cap off the end and called it good. It stopped it. Hope you figure it out.
As others have said, first check the torque, if the gasket isn't too trashed this may stop it. If not the diff needs to be dropped, in this case I have had better results with form in place sealer (silicone) and no gasket. Good idea to check the torque on the rear diff nuts at the same time.
Same thing happened here. Long day of racin' around the desert, leakin, tightened. Fixed immediately.
Sweet.
Thanks.
I'll do 19ft-lbs and call it good.
Ryan, did you notice my Edit with the rear diff. nut torque?
Sorry it took so long to find it, but my '94 FSM appears to have a weird error on the FF or disk brake rear axle, rear diff. drawing. (Chime ins appreciated) In the rear diff drawing it shows (erroneously of course, but confusing) a removable plate on the rear of the diff, in addition to the 3rd member being removed from the front of the diff. To top it off, the torque to the bolts or nuts that hold this mythical plate on is 36 ft lbs. Now, my first thought was that they somehow combined the SF and FF drawings by mistake. But, nooooo. - The SF drawing is complete, without FF influence and the torque for the bolts or nuts on the SF plate on back of diff is totally different. Do any other years FSMs have that error or is there a FF diff out there with a rear removable plate?
This happened to me under the same circumstances in Death Valley. The diff kind of squirmed around on the housing and ruined the paper gasket. I had to pull the diff and install a new paper gasket to make it leak free.
What are the specs for the front?
Those should be the same for all years.
18 ft.lbs front & 54 ft.lbs rear.
I added rear after I noticed that Kevin had suggested re-torquing rears while you were at it. Figured if you were thinking they were the same, you would't get the rears torqued correctly. Don't know other years, only what's in my '94 FSM.
From my 96 FSM:
Front differential carrier to axle housing: 20 ft-lbs
Rear differential carrier to axle housing: 54 ft-lbs
HTH!
Upon closer inspection, it looks like the paper gasket is all manked up.
I torqued the bolts to 20 ft-lbs; we'll see if that does the trick.
If not, ahh well. One of my inner axle seals is apparently slightly leaky as well. May as well turn it into a full weekend project.
Would be nice to swap out gear sets while the third(s) were off...
Ryan, have you checked that diff breather, as Cancruiser suggested? It could be, at least, contributing to your problems. Both inner seal and now this. I didn't have any leaks, but just happened to be checking the level recently and got a small wooosh when I opened the fill plug. Gave me the clue to check and fix my breather. You'll prolly have to do gasket anyway, but you'll also need to be sure about the breather.
