Leaking from...
Virginia Beach
I searched under diff breather and found numerous instructions for extensions, but what does it mean when fluid is coming out of the breather hose? The reason I ask is because this is happening on my front diff hose. I did a minor water crossing two weeks ago and went through a larger puddle fast, but fluid coming out of the hose? Does this mean I have water in the axle? If so, what next? Change diff oil, check birf packing.........?
I should of said to check the breather valve but it is good to check the valve.
If you had the nipple plugged and it released, it would be open now but that could be the reason for the oil in the hose if it was plugged.
I had a plugged valve, after a hot long trip the diff built up so much pressure that the hose poped off and blew oil all over the place.
Check your valve, they like to plug up.
I had a Toyota PUa long time ago that I put syn gear oil in the rear diff. As I drive down the road the syn oil blew out the breather. I drained the rest of the syn oil and filled with dino gear oil and all was well there after.
Cleaned
I pulled and cleaned my front breather hose while doing the front caliper replacement. I noticed that when I pulled the hose off, there was a sucking sound that took place. I didn't get a chance to check the diff oil level but am sure with the amount of fluid that was thrown, I should be ok.
Um, random fluid leaking isn't a good thing to use to conclude you have:
A - no water in the diff
B - clean and full diff oil
DougM
