Leaking a/c condenser?
Charlotte, NC
I have had to put in 134a every now and then to get the a/c to blow cold. Just yesterday I noticed a wet circle of fuild on the driveway under the front center of my truck. I placed a white piece of paper to check. The fluid is clear and slippery. It looks like a/c system oil. Is the condenser a common part for failure on an fj80?
According to the fsm the a/c condenser is sandwiched together with the radiator. Probably kind of a pain to get to looks like. Does it make sense to source a used part or get a new one?
Thanks, jt
If you saw the oil under the radiator, then yes, it could be the condenser. If it was under the DS side front bumper, it could also be the drier or lines to/from it.
If it was under the PS front seat/firewall, it could be the evaporator. In either case, it could also be just the o-rings gone bad.
The condenser is actually easy to replace. If you need to do so, I'd recommend a new one and OEM to boot. More than one story of a crappy aftermarket condenser going bad shortly after replacement, and the cost difference is not much. Definitely would not go used.
Thanks Tom. The leak is front and center, see attach pic. Actually look like it's coming from what I'm guessing is the evaporator coil. Can't find this in the fsm for some reason. Can anyone confrim this?
The condenser sits just above that crossmember, in front of the radiator (the pic you have is actually of the PS cooler). Before you sink a lot of $$ into a new condenser though, I'd check the pipe fitting on the DS side of the condenser to be sure that's not where the leak is coming from. If it is, you may just need to replace the o-ring.
Of course, you'll have to empty the system, evacuate and recharge as well, but that's small beer compared to a new condenser.
I was trying to figure out what that coil was. It looks like a oil loop cooler; so it's a ps cooler. Couldn't find that in the fsm for some reason.
So my initial guestimate is probably correct. I can handle an o-ring replacement on the condenser if thats the problem. I even have a vacuum pump but need a set of 134a gauges.
Cdan may even sell the correct o-ring(s). Gotta call him anyway for some belts and dizzy cap&rotor.
Thanks Tom
There is nothing on the 80's AC system that is 80 specific. That said, any competent AC shop should be able to help you out and do a proper repair.
I think TYC condensers are the best for fitment. Let me know if you need one, I have the o-rings too, it'll be around $100 +/- a few.
Just for the record, I sell tons of condensers, manufactured by several different companies, for almost every vehicle made and rarely do I ever see one come back because of failure. The part being damaged in shipping or a fitment issue is about the only time I see one returned.
ok - thanks. Not interested in taking it to the shop for this. I have done all the maintenance on my fj80, 7-series bimmer and 80s 911 for years. My wife's new Prius is another story. Just dropped almost $200 for an oil change, tire balance/rotate, and cabin air filter at the Stealership. :censor:
$100 for an new condenser doesn't sound too bad. Luckily I'm not down south, although would like to go back to NC/SC, so the a/c isn't super critical. If I'm lucky it's just the o-ring(s).
jt
I am halfway through replacing my condensor, drier, o rings, and rebuilding the compressor. It was not very hard to get to after I removed the grill and headlights.
I ordered the parts from coolstream in arizona, they have special prices for ih8mud members $165 for a denso condensor
It's doesn't sound that bad of a job. Something I heard regarding the o-rings; you may know this already. They should not be installed dry but lubricared with a/c oil.
I'll keep coolstream in mind - thanks.
X2 what TX Cruiser said.
FWIW, if you replace the condensor with an aftermarket unit, it will likely not have the mounting provisions for the JDM fan. This may or may not be of value to you. JM $.02
I'm going to heed warning to everyone looking for Denso parts once again. Their stuff has gone south since contracting with GM in the early part of the last decade. They don't care about quality anymore. No valve retainers in the 10S20 compressors and electric steering units in small GM cars is proof enough. I will not be putting any of their parts on any of my vehicles until they get their s*** straight. I certainly will not subject myself to being liable because of using their parts on vehicles I service. I do like their older stuff though.
Both of my vehicles have Nippondenso compressors, one is a 6E171 the other is what you guys have, a 10PA17C, both now are moving 134a. I did replace the front seal on the 6E171, but have done nothing to the Land Cruiser compressor. Neither system has a new drier, oil has been mixed, nothing has been flushed, but both will freeze you out.
The huge scam in the retro fitting department has to stop, and I'd be very cautious with the next retro fit issue when refrigerant HFO 1234yf comes around in the years ahead. Driers don't cost much, maybe $15 to a retail customer. Is it a good idea to replace it, yes, it is necessary, no. If the compressor locked up, you have no choice, replace it. Moisture boils when under vacuum at a much greater rate than when at atmospheric pressure. The only problem is leaving the system open for a great deal of time. 134a, oxygen and oil make an acid. Tape up the lines if you plan on making a week out of the job.
Pulled the condenser
I worked on my a/c problem tonite. The condenser was fairly easy to pull out. The only tight spot was the driver's side a/c fitting. I didn't see anything obvious; not even that much debris etc. Cleaned it with compressed air and replaced the o-rings. Now I have to get a set of 134a gauges and see the system holds vacuum. I'm tempted to just charge it and see what happens. The capacity is only about 2.5 small size cans. Which was should I go with this?:hhmm:
Thanks, jt
I had a small leak dripping from exactly the same spot, kept charging it every month. I replaced the condenser O-rings with no change in the leak. Finally broke down and replaced the condenser and drier when installing the JDM aux fan. No more leak and blows 34deg:cool: Local toyota charged $300 for the condenser and napa has a o-ring kit for a few bucks. Both came in next day. When i pulled the old condenser i couldn't see any obvious damage but no leaks anymore so there must be something wrong with it. I charged it with the HF gauge set and vacuume pump, PAG46 oil about 2oz and 3 cans of strait r134a. I had to source a can tap from a local auto parts store to use the small cans with the HF gauge set. I just thought you should know i had a leak with the same symptoms, and this fixed it for me.
Thanks Superjuice
So I'm off to HF to get a 134a gauge set. I will need it anyway for another car. Already have a vac pump I used on the house central air system with a set of r12/20 gauges.
When I was reinstalling the stuff last nite my thoughts were that I would be doing this again soon. :rolleyes: Thats the way things often work out. Oh well, c'est la vie. I did get the condenser in and out in less than 1 hour.
Pulling some vacuum on the system should tell the tail pretty quick.
Thanks, jt
I'm interested in buying if you're still selling. Do you ship to military PO Box?
