Leak on passenger floor
bpassmore
Site *****
Houston, Texas
Website
brettpassmore.com
I have a leak in my 80. It doesnt appear to be from the sunroof, but possibly the vents in front of the windscreen.
it starts rather high on the carpet in the passenger foot well. I can see 2 or 3 distinct "paths" of the fluid on the carpet.
Any thoughts?
Does it smell sweet like coolant? If so it's probably your heater core.
If it's just water, it could be the leaky windshield gasket, a loose firewall grommet allowing rainwater in, or it could be the A/C evaporator drain tube. It has been known to clog and fill up with water, spilling it onto the floor. Have you been running the A/C lately?
Is there an oder or color associated with the fluid. If so, check the FSM to eliminate the heater core(ouch) or a bad windshield seal.
I had a similar leak this past summer in a VERY heavy t-storm. I got a few drops that dripped off the bottom of the heater box onto the floor mat. Before that I had a worst problem with leaks in that area I had a leaky windshield gasket, leaky sunroof and the grommet fro the antenna wire was missing (PO cheapo antenna replacement) fixed all of that and its been fine for a year until that heavy rain. I also cleaned out the evaporator box and drain when I rebuilt the A/C system. Let me know if you can trace it to the vents at the bottom of the windshield because at this point its the only thing that would be leaking on my rig. Is you leak all the time or just when its raining? Like others have said if its the heater core it will smell sweet like maple syrup, unlikely the heater core IMO. Good luck
