Leak In Cargo Area
S. Jersey - New Germany
My rig is getting old I guess. It seems like I'm starting to get a lot of water leaking somewhere in the rear of my truck. The carpet in the back has been getting pretty wet and I'm not sure where the leak is. Any common area to start looking?
If it's on the passenger side, near the C pillar, it's probably the sunroof drain. That one gets pinched because of they way it was routed. The driver's side doesn't.
If it's near the wheel wells, look at the sliding windows. The belt molding can cause leaks under the windows.
If it's near the tailgate, look at the lift gate door seal.
The roof rack nutserts can also be a leak path.
FWIW, if it's the sunroof drain or roof rack, you're going to have a bad time fixing it. You have to pull the headliner away from the roof to get at those, and you can't easily do that with a '94.
I'll have to get someone to sit in the back while I simulate rain to see where the leak is coming from. I do have a leak in the front near the top corners of the windshield. I've seen water coming in there while going thru a car wash. Years ago I tried to make sure the drain holes in the sun roof were clear running wire and air thru but never really resolved it. I dread pulling that head liner down. Had a new windshield replaces with the OEM gasket 2Xs to try and solve that way but eventually gave up. Kind of figured it was coming from the roof.
I've heard numerous recommendations to clean the drain tubes, and I've had it done myself, before I understood what the problem was. I wouldn't recommend it now that I do. You can't get to the front tube connections, unless you're willing to sacrifice your headliner. You don't have to, and I wouldn't.
Run it though a good car wash. That simulates a good storm. When I was troubleshooting my leaks, I couldn't get it to fail in the driveway, but the carwash did every time.
If you've had an OEM glass and seal replacement, AND they followed the FSM procedure AND used sealant properly, the leak is the sunroof, but not the drains. It's the pinch drains in the rocker panels.
Open your rocker panel drain holes (the smaller of the two black plugs, on the outboard side of the rocker panel seam). That'll clean the void out. Run a long, thick zip tie into the pinch drains (you'll only be able to reach 4-inches into the rocker panel at most; that's all the room there is). This may clean them, it didn't work too well for me. The problem with the system is that the rocker panel inner surfaces were painted before they were joined (they're glued together). Sometimes too much sealant was used and the pinch drains don't work as well as they should. One of my 80s has this problem, the other two don't.
You can leave the plugs out, if you don't have saltwater on your roads. If you do, I'd leave them in. FWIW, the drain system is design to put water into the rocker panels; there's no way around it. Unless you reroute the front drains.
Rocker panel pinch drain
Rocker panel drain plug
I've also traced some leaking to my rear sliding windows. I found a seal out of alignment and some crud clogging them up. It was flowing into the cab and down the plastic panels.
^this
I do remember doing that a few years back but I forgot about them. I'll have to make sure they're draining again. Thanks!
Dust baby powder on the bare metal behind the plastic trim. Next time it leaks you will have a path in the powder that should help you find the culprit.
Good tip! I'll try that.
